Anonymous-0
I am having problems with the hydraulics on my 1985 5610. It first started with the P.T.O. not engaging with the tractor at idle or low RPM's. The PTO clutch pack had been rebuilt about 6 months befor this started. You could speed the tractor up and the PTO would engage and pull OK. As time passed (about another 6 months) the PTO will not engage at all unless the tractor is cold and the 3 point will not lift much weight unless the tractor is running at high RPM's. The warmer the tractor gets the worst the 3 point problem gets. Any ideas on were to start looking? The fluid and filter has been changed. Thanks
