DIY tank repair is easy cheap and works. keep it original as much as possible. Eastwood and POR 15 companies have an easy way to repair tanks with pinholes. welding a piece over a larger hole is no bigthang as long as the fumes are out. once the tank is clean, and you rebuild the carb another easy fix by the way and cheap too loosen tthe old girl up. Marvel Mystery Oil is good pour it in the cylinders and put in 4th gear and tow it around for 95 yards. let it sit, then drain the fluids, replace the oil, check the radiator for fliuds, check the wires to see if they are clean, connections are tight, and bright. recharge the battery, put new points in the distributor (another easy and cheap fix), replace the coil, and plugs set their gap to .025, and start her up. try starting her up without a new coil too. Let her run, and put her thorugh the paces but go easy on her and let her idle for 15 minutes, then increase the rpms, and let her run for 10 minutes and increase the rpms, and watch for oil pressure, and leaks out of the radiator, and temperature gauge. if you got her running and idling, then hop around and put her through the paces through the gears but go easy at first. same for rear lift. if you're lucky enough and the law of averages is on your side if it ran until parked she should fire up easy enough. work her a bit, and observe the gaskets and seals for leaks and focus your attention on those areas and begin to replace them sons of a guns. watch the smoke for black asmoke or white. listen for sputtering, and weird sounds. just focus on getting her started for now and ask questions. for now resist the temptation of washing her down with water. wait until she is started and running before the degreasing process and give it some time, and get to know her a bit, and learn the easy electricals for these things too to help you trouble shoot the ignition. you may want to replace the solonoid and ammter gauge too but just wait on that to see if she fires up. one thing at a time. loosen her up. get her started. watch her run and listen. write down troublesome areas. and ask questions. boinginbilly
