Order Ford 800 Parts Online
Ford 800 Oil Pressure Range
Cedar Grove
03-17-2005 11:25:23
Would you guys who work a Ford 800 tell me what the normal operating oil pressure is on your Ford?
Keith-OR
03-19-2005 13:02:04
 Ford 800 Oil Pressure Update in reply to Cedar Grove, 03-17-2005 11:25:23
Check my oil pressure gage off and on all day yesterday, as I was running my 5 foot Howard tiller. Stayed within 45 to 50 lbs pressure under full load ( was tilling as deep as my tiller would go)....Keith
txblu
03-18-2005 06:31:15
 Re: Ford 800 Oil Pressure Range in reply to Cedar Grove, 03-17-2005 11:25:23
30 Idle, hot, 60 pto rpm cold; 15w-40 OTR diesel truck oil. All my Fords of that era and thru the 1000 series are the same.
Mark
ken in wisconsin
03-17-2005 12:59:22
My 860 starts up cold at 80# or so and works itself down to as low as 25# at idle after it is warmed up.
Keith-OR
03-17-2005 11:40:48
Mine has been running at #50 so far. Was running at 35 to 40 before it broke a piston and I had to change motors. HTH.....Keith
mrstanley
03-17-2005 15:37:33
 Re: Ford 800 Oil Pressure Range in reply to Keith-OR, 03-17-2005 11:40:48
Mine runs at 42 lbs. hot or cold. I use Mobile 1
synthetic 10W50.
