Order Ford 2000 Parts Online
Ford 2000 Gas tank bolts
Kev in MO
03-17-2005 07:33:59
I bought a 1964 Ford 2000 4 cyl gas and noticed the gas tank was loose. All of the gas tank bolts are gone. Is there a rubber vibration dampener between the tank and mount? Does anyone know the size bolts I need? I"ll probably have to make them.
PatsPOS
03-17-2005 21:41:53
 Re: Ford 2000 Gas tank bolts in reply to Kev in MO, 03-17-2005 07:33:59
Kev...when I took the hood off "my" "63 4000, I found that the previous owner had replaced the no-doubt shot original rubber mounts with some ¼" shims. After I rattle-canned the engine the correct shade of blue, I reused the shims, but replaced the bolts with (I believe) 3/8" x 1¼" stainless bolts.
Might not be the greatest advice, but it should keep you running!
Pat
Kev in MO
03-18-2005 05:31:18
 kdvernon@socket.net in reply to PatsPOS, 03-17-2005 21:41:53
Thanks Pat, sounds like 1/4 shims should work for me too. Kev
