Company Logo Shop Now
Power steering fluid
RJJ
01-15-2005 19:59:23
I have two questions.
First what type of oil can I use in my 961 factory power steering pump. Second is why does the power steering fluid is always splashing out of the pump fill cap. It was leaking out of the breather in the cap so I pluged it an now I leaks it's way out from around the cap seal.
Thank You
RickB
01-16-2005 03:29:43
 Re: Power steering fluid in reply to RJJ, 01-15-2005 19:59:23
Easiest cheapest solution is to replace the filter. NH recommends 134 hydraulic oil, but many guys use dextron/mercon here with good results. I prefer the 134. Change the oil, then change the filter, then change the oil again. Cycle the steering each time, or crack the lines at the cylinder and work it manually to drain it. Post back if you are still having problems.
RJJ
01-16-2005 07:25:55
 Re: Power steering fluid in reply to RickB, 01-16-2005 03:29:43
Thanks Rick I'll give it a try. but it's got to warm up just a little aruond here first. -12deg, this morning.
Richard H.
01-16-2005 10:31:12
 Re: Power steering fluid in reply to RJJ, 01-16-2005 07:25:55
Yes what Rick said.. I use trans fluid my self with no problems.
To answer the question , your return filter or resivoir filter sponge is clogged probably. You may not have to change fluid twice if you are careful cleaning the sludge out of the bowl.
Where is it that cold? I"m in IND. 8 deg this morn.
RJJ
01-16-2005 16:07:31
 Re: Power steering fluid in reply to Richard H., 01-16-2005 10:31:12
WWWWIIIISSSCCCOOONNNSSSIIINNN
I shivvvver alllot wheeen I Typpppe.
RickB
01-16-2005 12:17:09
An extra 3 quarts of oil is a bunch cheaper than a pump or steering valve work.
Richard H.
01-16-2005 13:04:25
 Re: Power steering fluid in reply to RickB, 01-16-2005 12:17:09
Ya"ll but really" Change the oil, then the filter and then the oil."
RickB
01-16-2005 14:25:52
 Re: Power steering fluid in reply to Richard H., 01-16-2005 13:04:25
Get the contaminated oil out; no sense in contaminating a new filter with return oil from the valve/cylinder. Then change the oil and filter at the same time. First you were too cheap to buy two changes worth of oil, now you are complaining about only one filter change. If you don't like my advise, don't follow it. It is not your tractor that is puking oil anyhow.
RJJ
01-16-2005 16:24:47
 Re: Power steering fluid in reply to RickB, 01-16-2005 14:25:52
Thanks Guys
I will change the oil and filter twice just to make sure things are clean and flushed. Cheap insurance. Are the filters available at Ford/New Holland dealer?
Thanks to everyone for their advise.
RickB
01-16-2005 16:39:47
 Filter help in reply to RJJ, 01-16-2005 16:24:47
86502183 or AE33538A are the NH part numbers. The former for the earlier style pump with the reservior to the rear of the pump body; sort of a horizontal cylinder shape. The latter is for the later style with the reservior above the pump body; a vertical cylinder shape. The early style is a little spendy. I would call first, they may well have to be ordered in. I don't think either filter was used on anything built after 1964.
RJJ
01-16-2005 17:27:03
 Re: Filter help in reply to RickB, 01-16-2005 16:39:47
Thanks again Rick
Alot of people owe you big time for all your help. I have been watching these pages for along time now and several of you guy's have helped alot of people like me for some time now. I hope everyone takes the time to thank you for taking the time to answer all our questions.
Today's Featured Article - Oliver 550 Clutch Overhaul Tips - by Greg Sheppard. I got my 1964 Oliver Model 550 (serial 141-139-519) second-hand and used it for several years before the clutch began to slip. After taking up the pedal linkage several times I saw it was going to take more than that. The engine had been leaking oil at the rear seal and I suspected ... [Read Article]
Latest Ad: Allis Chalmers WD 45 runs, new tires, and original snap coupler implements plow, disc, brush hog. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
