Order Ford 841 Parts Online
841D ignition switch question
Bill F
01-01-2005 12:55:22
when I shut the switch off, the engine dont. Have I got a wire in the wrong place or other problem? (bought it doing this so not something new)
thanks
Bill
Hurley J. D.
01-02-2005 12:14:18
 Re: 841D ignition switch question in reply to Bill F, 01-01-2005 12:55:22
A switch can be installed in the pump and a new cover added. An injector pump place can do this. My dozer has a Rossa Master pump on it which is the same as the Ford pump and it will quit running when you turn the key off. I think that it would cost about $150 to convert the Ford where it quits when the key is turned off. I am not advocating this just offering some infromation if some one wants to go that way. The only advantage would be you would not forget to turn the key off and let the battery run down.
Hal/WA
01-02-2005 01:24:17
All the key switch does is turn on or off the ability to run the starter motor and glow plugs. This allows you to take the key out and maybe keep the little kids from messing with your tractor. But your diesel tractor will start with the key switch off if you turn the engine over some other way, like pull starting it, if the "throttle" lever is in the right position. It is also extremely easy to "hot wire" the diesel electric start system with a screwdriver or pair of pliers.
The way to turn off the diesel engine is to push the "throttle" lever as far up as it will go. You will want to turn off the key switch though, because if you don't your battery will go dead. Been there, done that!
Bill F
01-01-2005 18:04:25
Yes it is a 12 volt diesel and shutting off the throttle has been how I have been stopping it...just didn't know if something was wrong electrically.
Thanks guys
Bill
RWK in WI
01-01-2005 16:40:20
Do you have a gas or diesel? 841 D usually means diesel. or it could be a transmission transplant to a gas tractor.
Wayne in Iowa
01-01-2005 16:11:57
Gary is correct on the shutoff part and if the the red charge light works,turn off the key as not to run the battery down If it doesn't work is won't make any difference
old
01-01-2005 13:26:50
Sounds like its 123 volt convertion and if so some times you need a diode in line so it will not feed back from the alternator and keep running
Gary H.
01-01-2005 13:25:30
Diesels do not shut off with the switch-move the throttle FULLY up to shut off.
