Order Ford 4000 Parts Online
1964 Ford 4000 Dsi
John M88
09-09-2004 14:39:22
On the 64 Ford 4000 Dsi, I need to know if the Hyd Oil and Trans Oil are in separate compartments in the tractor. I believe that they are separate but been told otherwise. Thanks
FarmerDave
09-11-2004 06:07:43
 Re: 1964 Ford 4000 Dsi in reply to John M88, 09-09-2004 14:39:22
What's the chance the PTO drive shaft extends through the back two and has a seal that can leak where it passes through?
txblu
09-12-2004 06:34:57
 Re: 1964 Ford 4000 Dsi in reply to FarmerDave, 09-11-2004 06:07:43
Howabout excellent. Since there are 3 oil chambers and you have to get to the tranny, you go thru the hyd section. Some of mine leak together and mix the hyd fluid with GL-1, but I don't notice any performance problem (here in N. Texas). Don't want to do a split just for a little leak.
Mark
txblu
09-10-2004 09:50:10
as is the diff..... 3 compartments total.
Geo in SD
09-09-2004 16:42:13
Yep, they are separate from each other.
