Would a...
Casey in Ky
09-01-2004 18:32:06
aftermarket power steering kit for a Ford 4000 fit a 3000?? I"ve found a "used" one(never actually used, just opened the box) for $375 and was just was curious if they was interchangable? I don"t know the specifics on a 4000"s steering system or exactly where this aftermarket kit came, although I"m pretty sure it"s one of the $600 kits. Thanks. Casey
Robert (ID)
09-01-2004 20:22:48
 Re: Would a... in reply to Casey in Ky, 09-01-2004 18:32:06
casey if you end up not taking that let me know! i need one for a standard 4000! thanks
Bern
09-01-2004 19:17:29
If it was a 4000 "SU" model, then the answer would be "Yes, it would fit". If it was a standard 4000, the answer would be negative. A 4000 SU is a 4000 tractor with a 3000 front axle.
Carver
09-02-2004 14:10:00
 Re: Would a... in reply to Bern, 09-01-2004 19:17:29
Bern,
How would you be able to tell an SU from Standard?
Bern
09-02-2004 14:34:45
 SU in reply to Carver, 09-02-2004 14:10:00
It has the swept back, 3000, 600, 800, 8N, etc. style front axle. A standard 4000 has a straight front axle.
