Company Logo Shop Now
Order Ford 601 Parts Online
601 valve cover smoke
VC
04-26-2001 09:44:50
I have a 1960 641 and I have noticed that after running for a while smoke comes from the breater on the valve cover what causes this? It runs great and does not seem to use oil.
Thanks, VC
Joe
04-27-2001 18:26:13
 Re: 601 valve cover smoke in reply to VC, 04-26-2001 09:44:50
My 861 blew more smoke out of the breather than the exhaust. It didn't use much oil except when plowing in very tough ground. It ran fine and would have done so for a long time, but I decided to rebuild the engine. We found the cylinders to be out of round and some frozen rings. Thus the blow by. If you don't mind the smoke and it's not too bad I suggest living with it or look forward to spending about ( $1400 + ) for a overhaul. Please don't consider this advise, just a suggestion. Best of luck.
TomG
04-27-2001 02:24:35
It's probably blow-by, but I think I'd change the oil. If it still does it, a compression test might be a good idea. Of course, curing blow-by with an engine rebuild mostly is a matter of personal choice. Engines can run fine for a long time at reduced compression and power. Automotive emission controls have tended to sterilize ideas about engines. Most engines that have been in use for awhile have some blow-by. It's just that we don't see it anymore in cars. Itís a problem, I just donít know how to buy a used truck anymore.
albe
04-26-2001 13:34:11
Could be blow-by gases escaping past the rings into the crancase or just any volitiles that are in the crankcase oil that is "boiling off". albe
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
