Order Ford 2000 Parts Online
Ford 2000 I.D. info??
Don R
02-08-2004 10:14:44
I have read many postings about serial #s but I am still a bit unsure of the year, HP rating,PTO rating etc. I have a Ford 2000 3 cyl. with live PTO,6 spd trans,the hood has louvres on the side& the fenders are full to the bottom.(english?)The serial # is B086855,model 21023B,unit 8C05B.Thanks in advance for any info you may be able to supply!!!
Don R
02-10-2004 07:23:25
 Re: Ford 2000 I.D. info?? in reply to Don R, 02-08-2004 10:14:44
Thank you gentlemen I think I've got it straight now!!Don R
Phillip Lee
02-09-2004 16:37:52
Hi Don,
I just recently purchased a Ford 3000 diesel and had to figure out all the numbers. From what I learned, if your serial number starts with a B is was built in Basildon, England. The 8C05B should be the date code, which means it was built on March 5, 1968 by the day shift. I am not sure about the 21023B number but I think it should interpet as a Ford 2000(2), Agricultural All Purpose (10), Gas (2), Live 540 PTO (3) but I am not sure about the B in the number unless that indicates the 6 speed transmission.
Hope this helps,
Phillip
old
02-08-2004 11:42:31
My list has it at 30HP, Neb tests
