Order Ford 800 Parts Online
Ford 800 clutch problems
Dan R.
02-07-2004 10:22:22
Clutch stuck. Can't shift. Any cheap fixes?
RWK in WI
02-08-2004 07:39:50
 Re: Ford 800 clutch problems in reply to Dan R., 02-07-2004 10:22:22
I have had good luck by either starting the tractor in gear or forcing it in at idle and then working the tractor hard with the clutch pedal held down. Grading a drive / road or plowing in a field. I have also had luck towing a pickup truck and then having the pickup driver apply the brakes on the truck. Be careful what ever you do.
Gary-Miss
02-07-2004 17:35:55
You can try starting it up in gear by an extra wire to the solenoid, bypassing the neutral saftey switch. It doesn't usally work to jerk one around like this, but, most folks try once, anyway. It's not a hard job to split the tractor, free the clutch and put it back together, then, fasten the clutch down between uses. I have heard of some folks tying the clutch pedal down and walking off from it for a few days and sommetimes it comes loose. This won't take much effort and is worth a try.
Harrison
02-07-2004 19:31:08
 Re: Re: Ford 800 clutch problems in reply to Gary-Miss, 02-07-2004 17:35:55
See more recent post for similar problem.Old had a good trick.
