Order Ford 3000 Parts Online
3000 rearend leaking at transmission seam
bill
01-19-2004 18:03:58
before i spilt it.. the books dont show anything.
what is the seal supposed to be, between the trans and rear end???
Is the rearend open and only a gasket and the mating surfaces doing all the sealing??
Or is the rear end a closed housing and there is a seal out??
the fluid is pretty much pooring out as i add it from the bottom at the seam were the rearend meets the trans.. however the trans is holding oil...
thanks... bill
hay
01-20-2004 03:07:44
 Re: 3000 rearend leaking at transmission seam in reply to bill, 01-19-2004 18:03:58
there should be a metal gasket between the rear and trans. the tractor will have to be split to install it. make sure the gasket has no kinks.
Mike
01-19-2004 19:22:47
Bill,
If you check your books further I'll bet you'll find you should have a rear seal in the transmission, just a hunch. Good luck.
Mike
