Order Ford NAA Parts Online
5? ford jubilee
Jim Eaton
01-11-2004 13:23:56
I'v got a ford jubilee tractor I'm not shure of the year its around a 53 it has a 12 volt battery in it and I was wondering if that was right? it also has a postive grounding system is that right? I want to sell it but I wanted to get it running first, Thanks for any help, Jim
john charles
02-14-2004 11:38:03
 Re: 5? ford jubilee in reply to Jim Eaton, 01-11-2004 13:23:56
i/we currently have a new old stock lucas starter for sale exchange or outright of the ford jubilee tractor. contact us at info@acewichita.com
Daniel
01-12-2004 05:57:36
Sounds like someone who didn't know what they were doing put a twelve volt battery in a six volt system. Are there any wires that appear burnt? If there are, major components like the coil, starter, generator/alternator could be fried and your going to need to rebuild the electrial system in order to get it to fire up.
Larry NCKS
01-11-2004 15:12:29
If it's a Jubilee it's a '53. The same tractor was built in '54 as an NAA. The original battery would have been a 6 volt positive ground. If the system has been converted to 12 volt, one would think it should be negative ground.
TimK
01-13-2004 11:48:47
 Re: Re: 5? ford jubilee in reply to Larry NCKS, 01-11-2004 15:12:29
Since it has a 12v battery, it should have an alternator. If it does not, then someone just shoved a 12v battery in it and no more of the necessary conversion items needed to go to 12v. If this is the case, and you'll have to do some investigation to see if this is the case, you have to decide if you want to finish the conversion to 12v., or return it to 6v. If it was running on 12v., with no reduction resister, you'll probably need new coil, points, condenser, and a check to see if the voltage regulator and 6v generator still work. Running a 6v on 12v would do no damage to the generator, starter, wiring or starter switch, although the coil was probably fried and now won't work on 6 or 12 volts. If the 6v generator needs work, then I guess I would consider finishing the conversion to 12v starting with a new alternator etc.
Jim Eaton
01-13-2004 16:13:49
 Re: Re: Re: 5? ford jubilee in reply to TimK, 01-13-2004 11:48:47
Just wanted to thank every one for the info, it helped and the tractor runs great now, if you know any one that is in the market for one let me know and I'll send them the info,again thanks Jim
