Order Ford 801 Parts Online
Re: 801 engine confusion
Tony Jacobs
03-25-2001 21:35:09
Hello Clifford, Mr S. is right that is a Diesel block 1958 or 1959 according to the casting number you gave , the 901 marking could have been ear marked for 901 rowcrop on the assembly line then not used or ? Was this a new block or a used one ? Was there a gear on the crank and balancer assembly bolted to the block ? Thanks Tony Jacobs
clifford file
03-26-2001 03:39:42
 Re: Re: 801 engine confusion in reply to Tony Jacobs , 03-25-2001 21:35:09
This is a new block assembly and yes there is a gear on the crank but the weights haven't been added yet. An old man inherited this block from his brother and wants to sell it for $900 which seems pretty cheap. My situation is that I have a gas 851 and it has thrown a rod through the block so unless I buy an old diesel engine for parts and convert my tractor, this deal doesn't do me much good. How hard would it be to convert to diesel? A guy in Indiana offered to sell me a complete diesel engine that he says runs good but has a repaired block from maybe overtightening a headbolt. Any advice as to the direction I should take. I can apparently have a new diesel engine this way as cheap as I can buy a remanufactured gas short block.
Tony Jacobs
03-26-2001 21:03:25
 Re: Re: Re: 801 engine confusion in reply to clifford file, 03-26-2001 03:39:42
Hello Clifford , I have converted from gas to Diesel and from Diesel to gas , that's not the hard part getting all the parts is harder and more expensive. Starting with the new block is good but then after getting and rebuilding the parts , like the head , injection pump , nozzles you be into the project for more than just getting a block and rebuilding your gas engine. Where are you located ? I live in Mass. , I have gas blocks with cranks rods and pistons that just need to be rebuilt but are not blown up and I would be interested in buying that Diesel as I have three other Diesel tractors. What is the casting number on the side of your gas engine ? Thank Tony Jacobs
clifford file
03-27-2001 04:09:04
 Re: Re: Re: Re: 801 engine confusion in reply to Tony Jacobs , 03-26-2001 21:03:25
I understand. I figure that I'd have close to $1700 in the diesel if I bought the block assembly and an old motor for parts, about the same if I buy a remanufactured short block for my gas. I know I can rebuild a gas engine cheaper, I already found an old gas engine I can get for $500 ($350 plus shipping) and $500 for a rebuild kit plus head work and gasket kit gets me out for about 1200 or less. I'm just not sure about rebuilding one, I've never done it and just knowing what needs to be machined, then what bearings to order, etc. could be a problem. I figured I could handle assembly from the short block up. Anyway my casting number is EAF 6015-J and I live in Morganton, NC 28655. You can call me at 828-433-2423 days or 433-5406 nights about getting the diesel block assembly.
Tony Jacobs
03-27-2001 21:43:31
 Re: Re: Re: Re: Re: 801 engine confusion in reply to clifford file, 03-27-2001 04:09:04
Hi Clifford , I will e-mail you and give you a call as soon as I can , Thanks Tony
clifford file
03-28-2001 14:11:40
 Re: Re: Re: Re: Re: Re: 801 engine confusion in reply to Tony Jacobs , 03-27-2001 21:43:31
Tony I looked at the diesel block on Saturday but didn't buy it because I knew it wouldn't work with my head. If it's still available, I am willing to buy the block and let you reimburse me for it. Would you be willing to send me a check for $900 for the new block assembly and an old gas motor as a core with return shipping prepaid for the diesel block. You'd get a new block for several hundred less than you could buy a remanufactured one, and I'd have a gas block, crank and cam, etc to rebuild for my tractor out of the deal.
Tony Jacobs
03-28-2001 20:50:32
 Re: Re: Re: Re: Re: Re: Re: 801 engine confusion in reply to clifford file, 03-28-2001 14:11:40
Hi Clifford , I sent you an e-mail yesterday , and tried to call you this evening , I will call you on Thursday and you can try me also , my number is 1-413-267-5087 . Thanks Tony Jacobs
