Front Spindle Bushings
seedsntrees
09-09-2003 18:17:07
How difficult is it to replace the front spindle bearing and bushings on a 1959 601?
Thanks!
dhunter in WV
09-11-2003 15:16:10
 Re: Front Spindle Bushings in reply to seedsntrees, 09-09-2003 18:17:07
Please excuse my ignorance, but is the spindle the same thing as the axle pin?
seedsntrees
09-11-2003 22:51:04
 Re: Re: Front Spindle Bushings in reply to dhunter in WV, 09-11-2003 15:16:10
Hunter, I think you are talking about the single front axle pin. I'm talking about the front (two) wheel spindles.
Tom
09-10-2003 04:27:34
REcommend you get a real brand Ford/NH Repair Manual first. Follow it to the letter. Easy job.
Don't get off-brand or IT Manual - waste of money.
Roger
09-09-2003 19:05:51
I'm assuming this is an all-purpose or wide front, tractor. The worst part is usually removing the old bushings. They're usually worn very thin and it can be a pain to get them out. Sometimes it's worth removing the outer axle from the center section (after the spindle is removed) so it can be put in a vise for better access. I've had some that I've had to drive a thin, narrow screwdriver blade (which I've modified for this job) behind the bushing to split it lengthwise, then pull it out. Inspect the spindles, they're probably worn in the bearing areas. Worn spindles will eat up new bushings in short order. The thrust bearing just slips over the spindle so it's usually quite loose. Hope this helps...
