Order Ford 4000 Parts Online
Plowing with 4000
Big Matt
08-05-2003 09:37:49
Have a '70 Ford 4000, gas. What size plow could this tractor pull? 2, 3, 4 bottom plow? Looking at the ads in the classifieds, I am not sure what the tractor can handle.
Thanks.
Matt
Joe(TX)
08-06-2003 20:13:18
 Re: Plowing with 4000 in reply to Big Matt, 08-05-2003 09:37:49
I can easily pull 3 14in bottoms with my 61 4000 4 cyl which has less horspower and weight.
Jonathan
08-06-2003 18:36:57
At home we use to have a Ford 4630 loader tractor, and having three 16's on medium type soil was enough for it. Mind you it was a very heavily build plow. A Ford 4630 is a modern equivalent of the 4000.
Van(WA)
08-05-2003 18:01:43
Matt; I have two 4000"s, and a two bottom plow is all they want!!!!, you may get by with a three bottom under certain conditions, depends on soil type, size of plow ect..... ....
Charlie
08-05-2003 10:30:47
Matt
A 70 Ford 4000 gas should have around 50-52 HP with should be able to pull 4 bottom 14in plows or 3 bottm 16in plows. It really is going to depend on what kind of soil type you have. Clays are harder to turnover, sandy soils are easier. Just my oppion
Charlie
Rod F.
08-05-2003 20:33:40
 Re: Re: Plowing with 4000 in reply to Charlie, 08-05-2003 10:30:47
We used to pull 3 12's with our 4000. Mostly medium to light soil, and never had any trouble. Probably would take 4 12's ok. Just be aware, that if you are looking at a modern European plow like a Kverneland, the 4000 probably couldn't put daylight under any more than 3 furrows. A three furrow model AB weighs in around 1800 pounds, and 8-10 feet out behind. I have a four furrow on my 7710, and with no front ballast, I can lift the front of the tractor with one hand when the plow is in the air. Front weight is a must. Take care.
Rod
