Egg Crate Grill Color
JVO
05-29-2003 19:36:37
I inquired about a 861 Powermaster on "Chats Tractors". It is a 1960 and they have the subject grille painted gray just like the rest of the gray tin on the tractor. I think it should be red. I asked the people about it and they said it came gray like that from the factory. I still don't believe they are right. But if enough of you say that some did come from the factory with solid gray grilles(egg crate 860 series) instead of red I will change my stance. Waiting to hear your opinions!
FWIW
05-30-2003 18:35:46
 Re: Egg Crate Grill Color in reply to JVO, 05-29-2003 19:36:37
In late 1957 Ford changed and upgraded the colors and cosmetic design of the 800/801 Series tractors. From 53-57 the grille was a one piece vertical bar grille.
For example go to the tractor photos section and find a Jubilee or NAA with this grille type (should be grey according to factory) and compare to an 801 picture.
In late 57 the 'egg crate' grille with a folded metal screen grille behind it appeared. This was actually a three part grille: the lower grille assembly that was red. The upper and outer egg-crate in red, and the inner screen grille piece in grey.
For the Powermaster 801's this red/orange color was also applied to the nose cone and upper hood/gas tank door and the dash panel. The lower dash panel was grey.
Dave in MD
05-30-2003 08:42:44
I've asked about these grills before too. I recently got an 861 that has the gray vert slot grill on it & have been told it should be the red 'egg crate'. I've seen many pics of 800/801 and there's a mix of grill styles but I can't determine a pattern. Does anybody know if there was a change in production and at what point? Were different grills used on the different models? Diogenes
Jim.UT
05-30-2003 12:40:26
 Re: Re: Egg Crate Grill Color in reply to Dave in MD, 05-30-2003 08:42:44
Here's the way I understand it:
'53 & '54 Jubilee/NAA: gray grille with thin vertical fins and a round crank hole at the bottom.
'55-'57 600/800: Same as NAA grille except the crank hole is oval.
'58-'62 601: same as the 600/800.
'58-'62 801: red square grid grille
The rowcrop tractors (700/900 and 701/901) follow the same trend as the 600/800 and 601/801 except I think the grilles on those tractors are not as tall....I could be wrong on that.
That's the way I understand it. I'm open for correction if I'm mis-stating the facts.
Dave in Md
06-01-2003 06:41:49
 Re: Re: Re: Egg Crate Grill Color in reply to Jim.UT, 05-30-2003 12:40:26
Thanks for all the info. Looks like I've got a '60 model 861 with early sheet metal on it.
RED!.....Jim.UT
05-29-2003 21:14:19
Well, sorta red-orange. Same color as the big stripe down the center of the hood. Look in the Gallery (link on the left) for some examples.
