Good idea or not
cooling system question
Tom
04-29-2003 16:48:29
Pulled the original radiator. I'm Recoring the radiator to save the 5-59 stamped upper tank abd keep it as origginal as possible. Noticed that the original core was all plugged up and holes in top of core were about 70% solid closed.
Question about water pump:
If it ain't broke don't fix it? or while I have the Front End Loader , hood assembly, and gas tank removed is it a good idea to replace the original water pump now?
What would you do? 1959 water pump.
Comments?
Tom (TX)
04-30-2003 15:16:18
 Re: Good idea or not - cooling system question in reply to Tom, 04-29-2003 16:48:29
I agree with the guy below. Change the belts, upper hose, lower hose, clamps, thermostat, and have the water pump rebuilt by a rebuilding shop. They can usually put in all new seals, bearings, gaskets, and throughly clean everything.
bill
04-30-2003 05:54:47
CHANGE the pump, belts and hoses... run it ten minutes.. then tighten all the hoses and belts..
its a nightmare to work around the loader later..
you'll be far far ahead.. good luck.. bill
Van(WA)
04-29-2003 17:43:49
Tom; I would, money well spent, will save you lots of work later on, also would change the belts while you are at it!
