Ford 950 Remote Lift Question
Ed
04-28-2003 09:33:43
My 950 has single lever remote control unit mounted under the seat. When a remote cylinder is attached there is no lift under load unless the three point lift arms are chained down. Without a load it will operate a remote cylinder slowly. The hydraulic pump has been rebuilt and has plenty of lift on the three point arms. Any suggestions on a fix? I have assumed that a 950 can operate both the three point arms and a remote cylinder at the same time.
John IA.
04-29-2003 19:29:54
 Re: Ford 950 Remote Lift Question in reply to Ed, 04-28-2003 09:33:43
Ed, I have replaced my single valve with a dual on my 861.With one remote to the loader and the other to the rear. And mine will only run one end at a time. The part I can't figure out is why you have to chain your 3 point down. There are rubber o-rings under that auxillary valve that could be blowed. John
Ed
04-30-2003 06:57:29
 Re: Re: Ford 950 Remote Lift Question in reply to John IA., 04-29-2003 19:29:54
Thanks John. I am going rebuild the auxillary valve and see if that works. The chaining down of the arms comes from my experience with NAA's that use a remote cylinder without an auxillary valve.
