Fact or Fiction
ron
04-26-2003 20:00:39
I had someone tell me that if you add 1 cup of motor oil to the cooling system it will keep your water pump lubricated and never have trouble. Comments anyone?
Fiction.................TimK
04-28-2003 11:20:26
 Re: Fact or Fiction in reply to ron, 04-26-2003 20:00:39
junior
04-27-2003 13:38:20
I dont believe you should put motor oil anywhere but the crankcase. Did you ask this misinformed individual if he does the same thing with his automobile?
paul
04-27-2003 08:44:04
Bad idea for several reasons. Oil & water don't mix. You'll never be able to sell it, folks will figure a blown head gasket.
A can of coolant lubricant is cheap at the supply store, & will actually do a good job without the milky mess & bubbles & foam.
--->Paul
tlak
04-27-2003 03:54:20
That much will turn your coolant milky. You can buy water pump lubricant.
Gary-Miss
04-27-2003 12:06:26
 Re: Re: Fact or Fiction in reply to tlak, 04-27-2003 03:54:20
The bearings in water pumps are sealed from the water. A tablespoon or less of brake fluid will lubricate the seal. A change of antifreeze is better, though.
