Re: Stabalizer bars
Author |
Lee
04-21-2003 09:37:16
Nathan, The stabilizer bars should line up with the pivot point on the lower arms on your 3-point. You may have the same problem I just ran into on a 53 NAA. Someone had replaced the fender brackets(where the stabilizer ends attach under the axles) and had used an incorrect bracket. When I went to install the stabilizer bars they seemed to be too long. The fender brackets that had been used only had the 2 center holes and were missing the outer holes needed to fit. The ends of the stabilizer bars weren't lined up with the lower arms of the 3-point. I replaced the fender brackets with the correct ones and the stabilizers were in line and fit just fine. Good luck, Lee
Nathan
04-21-2003 09:54:52
Re: Re: Stabalizer bars in reply to Lee, 04-21-2003 09:37:16
Lee, The pins are in line with the lower 3 point arms. The arms that I got are too long.
RWK in WI
04-21-2003 17:16:55
Re: Re: Re: Stabalizer bars in reply to Nathan, 04-21-2003 09:54:52
By any chance are you trying to hook up to a piece of equipment that has the pins set wider than 26". If the equipment is too wide is spreads the arms apart and it looks like the stabilizers are too long.
Nathan
04-21-2003 18:53:06
Re: Re: Re: Re: Stabalizer bars in reply to RWK in WI, 04-21-2003 17:16:55
It might be 26 1/2. The center to center hole dimension on the bars that I have is 33 inches.
Lee
04-21-2003 10:07:01
Nathan, I think they only make 2 lengths of stabilizer arms for these things. If I were you I'd check with the company you bought them from and see if maybe they didn't send you the wrong ones. As long as the pin in the bracket is pointing directly at the pin on the 3-point and not forward or behind it you should be good to go. Later, Lee
Nathan
04-21-2003 10:40:41
Re: Re: Re: Re: Stabalizer bars in reply to Lee, 04-21-2003 10:07:01
Lee Thanks for your advice.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
990 7 foot mower conditioner john deere hay rake pto driven john deere head carrier
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
