Order Ford 601 Parts Online
Ford 601 rearend repair
Jim
04-15-2003 03:41:45
Has anyone out there put in the big differrential ring gear on ford 601? Do I need to replace pinion etc. when I put in new ring gear? I can see through the cover that the ring gear has a couple of teeth knocked off. How big of job for ring only, or for ring and pinion? My book shows special tools needed for pinion assembly? Thanks, Jim
Sam MI
04-15-2003 15:11:25
 Re: Ford 601 rearend repair in reply to Jim, 04-15-2003 03:41:45
Hi Jim; I rebuilt the rear end on my 601 recently. If the machine was new it would be wise to replace gears as a matched set, however at fourty plus years old I would get a ring gear from a salvage yard. The ring gear is riveted to the carrier. Bolts are available for the replacement gear. HTH
