It sounds like you did well. I think you will like the 640. I use my 641D in the woods a lot. It has a heavy duty step through loader that is my most used implement. I have hauled just about anything in that loader, including firewood, rocks, gravel, dirt and lots of tools. For the woods, I leave my tire chains on until it gets really dry in the late spring--it really helps the traction when you have a heavy load in the bucket. If I were you, I would look for a loader to fit your tractor. I also have a very heavy rear blade that I keep on the tractor much of the time, partly as a counter weight and partly to use as a blade. I have pulled small stumps with a log chain hooked to the rear blade framework and have been able to remove some with the loader. Larger stumps are beyone the traction capability of my tractor. If you try to remove stumps, avoid the temptation to pull from the upper 3 point mount. It is possible to lift the front wheels of the tractor off the ground and flip the tractor over on you!!! And never jerk a chain or cable--they can break and the loose end could possibly hit you. Also be very careful on any slopes. A ROPS is probably a very good investment. I would suggest being very familiar with your tractor and know how it responds to the various controls before driving it in the woods very much. Watch out for stump holes and other sudden changes in the terrain that could be dangerous to you. And have your tractor and any other vehicle or implement well away from trees that you are cutting down. (Don't ask!) Have fun with your new purchase, but be safe. Good luck
