Re: injector pump losing prime
Oldfarmboy Jim
04-03-2003 20:33:46
Ernie,
I had the same problem with a Case 380 CK after I changed the filters. A gent named Elmer over on the Case discussion board advised me to suspect a partial blockage rather than small air leak. He recommended removing each of the fuel lines and blowing them out with compressed air. I also drained the tank and flushed it several times with a gallon of fuel that I filtered after each flush. Sure enough, the problem was solved with no further occurrences. Good luck on this. Jim
