Live v. non-live PTO
Chuck
04-03-2003 15:30:35
I have an opportunity to buy a 600 series ford tractor with live PTO, is this a big advantage over non-live PTO?? (Comparing 660 model to 650 model).
Dave
04-04-2003 07:07:05
 Re: Live v. non-live PTO in reply to Chuck, 04-03-2003 15:30:35
If you're going to be cutting heavy brush with a bush hog live power is the only way to go. You can drive into the brush and if the cutting gets heavy, depress the clutch part way stoping the forward motion of the tractor, but continuing to grind the brush.
bill
04-03-2003 16:41:16
depends..can be terrific.. for instance when i am running the hay baler or hay cutter,, i can change gears for corners and heavery crops with out shutting down the baler.. why the tractor is still rolling and baling, i simple very quickly grab a higher or lower gear. but the heavy load on the baler.. just keeps on going..
older tractor shut every thing down when you depress the clutch..
Chuck
04-03-2003 15:38:56
What is a good price range for 660 and 650?
