Order Ford 801 Parts Online
801 rebuilt engine leaks around hydraulic pump
Jon (IN)
03-29-2003 11:58:39
I recently rebuilt the engine in my 801 ford. Got everything bolted back up to the point where I can start it. I do not have the hydraulic pump bolted on. I started the tractor and brought it up to temperature. I noticed I was leaking oil around where the hydraulic pump bolts on. Would this be normal? I am hoping that it is and that is how the pump gear is lubricated. If this is the case is there a gasket between the block and the hydraulic pump? Thanks,
Jon
Yes. Tom
03-29-2003 14:28:02
 Re: 801 rebuilt engine leaks around hydraulic pump in reply to Jon (IN), 03-29-2003 11:58:39
Yes, thre is a gasket between the hydraulic pump and the motor block (where the gear is located).
Yes, they tend to leak a bit. The gasket helps. Cheap...
I ordered one from FNH and got 5 in a pack. Send me your address, I'll send two. No charge. Tom
Yes. Tom
03-29-2003 14:27:38
Jon (IN)
03-31-2003 08:45:53
 Re: Re: 801 rebuilt engine leaks around hydraulic pump in reply to Yes. Tom, 03-29-2003 14:27:38
Thanks Tom. I have sent my address to your hotmail account.
