Ford 231 clutch and 3pt. lift problems.
Ossie Smith
03-28-2003 18:09:44
Have a Ford 231 ,some tell me this is the same as a 2000 Ford, clutch has gone out on it. Is it a two stage clutch or a single stage one? Looked in Value Built cataloge and they do list a clutch for a Ford 231 which is an industrial tractor which is what I think mine is??? Now the lift on the 231 has stoped working after working very erraticly for some time, Anyone know if this is the same pump that is in the 2000 Ford?? or what pump is in the lift of a 231.
Thanks for your help
SCOTT
03-31-2003 22:21:40
 Re: Ford 231 clutch and 3pt. lift problems. in reply to Ossie Smith, 03-28-2003 18:09:44
YOUR DUEL CLUTCH ALSO RUNS THE SHAFT THAT TURNS THE PUMP. I BET YOU WILL NEED TO CHANGE THE CLUTCH IN IT.IF YOU DO PLEASE GIVE ME SHOUT I HAVE THE CLUTCH KITS FOR ABOUT $300 EXCHANGE.LET ME KNOW IF I CAN HELP IN ANYWAY.
