Order Ford 3000 Parts Online
Re: Ford 3000 clutch
Gary-Miss
03-27-2003 06:15:31
Yes-Unplug the wiring harness in front of the fuel tank, shut the fuel off,disconnect the fuel return, remove the bolts that fasten the fuel tank bracket to the back of the head, remove the tied rods, remove the four half inch bolts that hold the steering box to the clutch housing, go through the steering wheel to the housing with a suitable rope, chain, belt, etc and lift the whole unit intact off the tractor. You would be advised to remove this if you were going to replace the clutch anyway, so, you will be that far ahead of the game. Good luck.
