Re: 3 pt Lift Hieght
Hugh
03-24-2003 11:42:29
Wayne, it sounds like your problem may be that the cam follower pin is worn, or the lift linkage may be out of whack. In either case, if these are your problems you'll have to remove the lift cover to adjust the linkage and replace the pin. Not a bad job, but the lift cover is very heavy. Definitely just my $.02 worth. Good luck.
