Order Ford 4000 Parts Online
Re: Pistons-4000 Ford Gas
Gary H.
03-22-2003 03:56:18
What you might consider is taking the block to your local machine shop. Have them over bore it and install sleeves that are thick enough to take it back to standard. You won't have to worry that you had leak in the sidewall do to block rot. We've had this done before at work. Could cost you about $50-70 per hole to do. Hope this helps.
