Order Ford 4000 Parts Online
Pistons-4000 Ford Gas
Charles Jackson
03-20-2003 07:15:28
Desperately need a source for 3 pistons for a
1966 4000 Ford with 192 ci. gas engine. Orignially
4.4 bore now is .030 overbore. No longer avail.
form Ford and my aftermarket sources has not found
them. Thanks for any help.
Gary H.
03-22-2003 03:56:18
 Re: Pistons-4000 Ford Gas in reply to Charles Jackson, 03-20-2003 07:15:28
What you might consider is taking the block to your local machine shop. Have them over bore it and install sleeves that are thick enough to take it back to standard. You won't have to worry that you had leak in the sidewall do to block rot. We've had this done before at work. Could cost you about $50-70 per hole to do. Hope this helps.
Bill Neal
03-20-2003 14:40:08
I have an as new 3cyl gas engine (it has never run) from a '64 Ford 4000; aquired when I bought a complete drive train with manual tranny to replace my defective SOS. Interested? I am about 75 mi. NE of Winnipeg.
Charles Jackson
03-20-2003 21:08:47
 Re: Re: Pistons-4000 Ford Gas in reply to Bill Neal, 03-20-2003 14:40:08
I am in Western KY. If we were closer I might be
interested. I still have hope that I will be
able to find the pistons I need. Thanks for the
info. If anything else develops I will be in touch.
