Company Logo Shop Now
Re: Fuel shutoff valve
Check the archives.... they are repairable
03-17-2003 18:28:15
Some of the new replacement valves (which I think were in the $30 range) had a problem with O rings going bad in storage. There were some guys here who found a way to drill out the pin that keeps the valve from being screwed out of the housing completely, and they were able to replace the O ring with a quality one. If you check the archives you may find out more. I'm pretty sure all the original type valves are rebuildable in this fashion.
Truck
Gav-n-Tn
03-17-2003 19:46:03
 Re: Re: Fuel shutoff valve in reply to Check the archives.... they are repairable, 03-17-2003 18:28:15
Another thing to look for,mine was leaking and I realised that it was opened up too far.I turned it in and backed it out just enough to flow and stopped the leak.Also, there is an o-ring between the cut off and the tank that seals it and is also renewable as it can be purchased seperately from the shut off.
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
