Order Ford NAA Parts Online
Auxilary hydraulic pumpbackhoe on an naa ford??????
Terry
03-11-2003 16:52:54
I would like to know if it is possible to mount an auxilary hydraulic pump on the front of the engine of my naa ford? I am planning on building a sub frame that will extend past the front of the tractor, and putting a plow on it for the winter, but also want to be able to hook a backhoe onto the rear of the tractor via the 3 point hitch. The backhoe is a Bobcat model 909,and requires 14gpm in order to operate. The pump I am lookink at is capable of 20 gpm @1800 rpm. Any input that I get would be greatly appreciated. Thanks. Terry
Don H
03-12-2003 08:14:40
 Re: auxilary hydraulic pumpbackhoe on an naa ford?????? in reply to Terry, 03-11-2003 16:52:54
Don't forget you will need a big reservoir. Away to go might be with a prince pto pump and reservoir attached to the backhoe. You could the use a smaller pump and reservoir maybe even electric to run a snow plow. I don't know your tractor maybe your pto wont run in nuetral. Just a thought.
Have fun Don
Tractor Dan
03-11-2003 17:45:04
It should work i have mounted a aux pump on the from of a case to supply hydr power for a mid mount mower for the local high way department just had to had a shaft made at the machine shope but worked great and with pump having extra capacity it may work a little quicker but good luck let me know how it works out
