Re: 8 volt battery
Timk
03-11-2003 14:33:02
Don't do it. 8 volt batteries are just temporary cover ups for other electrical problem. Plus, while you may be able to crank up your regulator enough to charge it some, that will always be an issue, and there are no 8v. battery chargers that I know of. Also, you will need some sort of special resister to bring down the voltage to the coil so you don't fry it. A good 6v with clean connections and good system will do ok. If you must change over, then go the route and cnvert to 12v. There are lots of those kits on the market. My $.02
