Re: 12 volt conversion
opp
03-09-2003 19:40:24
When you take the cable off, you are killing the power to the coil. The engine can't run without the coil.
BC
03-09-2003 21:37:30
 Re: Re: 12 volt conversion in reply to opp, 03-09-2003 19:40:24
Thanks for your reply.. but should'nt the alternator
supply the coil with voltage? you may have to excuse
me i may be looking at this like it were a car. THANKS
opp
03-10-2003 07:19:31
 Re: Re: Re: 12 volt conversion in reply to BC, 03-09-2003 21:37:30
I was wondering that, but a car doesn't use a one wire alternator (Does that make a difference? I don't know). Did you try disconnecting the cable at full throttle? I have heard that the one wire alternators need a lot of RMPs.
