Order Ford NAA Parts Online
Ford Jubilee Blowing Oil
totzilla
03-05-2003 11:22:35
First I would like to say hello to the group.I am considering buying a Ford Jubilee (640 I'm not sure)
the fellow that is selling the tractor says it blows oil out the oil breather cap. Could this be fixed easily or is it a symptom of something more serious... by the way the tractor has a Ford loader on it and the asking price is $1500 negotiable.Thanks in advance for your response.
buck
03-05-2003 19:21:17
 Re: Ford Jubilee Blowing Oil in reply to totzilla, 03-05-2003 11:22:35
Before you go too far check the engine oil level. Overfill or fuel in the oil will cause oil to blow out the vent/fill tube.
raytasch
03-05-2003 16:47:07
Jubilee, NAA, hundred series, will have the same engine family. Make sure the oil breather on the right side of the valve cover is not stopped up and the filler cap is not stopped up. If both of these crankcase ventilation devices are clean you have blowby which will take a little work and a lot of money to fix.
ray
