Oil change
j d
03-04-2003 04:18:52
I have a 67 ford 3000 diesel that I use for mowing. I put about 50 to 60 hours on the tractor each year. My question---should I change the oil and filter each spring, change the oil only, or use the same oil for several years? thanks.
jw57
03-05-2003 17:03:24
 Re: oil change in reply to j d, 03-04-2003 04:18:52
van is right to tellyou to change the filter every time.in addition to the air cleaner , if you own a 3 with an in-line pump you should change that oil too. just use same type as in the motor. if you have a distributor type pump there is no oil to change as the fuel lubricates the pump just be sure to never run the tractor with number 1 diesel in the tank durin g warm weather
jw57
03-05-2003 17:02:53
Van(WA)
03-04-2003 07:21:55
JD; Oil is "cheap" compared to overhauls, changed oil and filter (also filter for diesel fuel) at least once a year,always changed new filter with oil change. Makes no sense to run clean oil thru a dirty filter!! Don't forget the "air cleaner" , Very important.
