Just got a 2N-my first tractor
a few questions
Reno, Hudson Ri
04-25-2000 21:18:16
I took delivery on a 1943 2N the other day. Right after I hit the shed wall, I realized its clutch is on the left, not the right. I had driven an 8N a few days before that and could swear the 8N clutch was on the right. Am I crazy? Everybody says to shut off the gasoline when not in use. OK, but why?
The hydraulic hitch arms have to be chained down to the axle when the loader is in use. Is this normal? Is it OK? They worked fine, when I released them, but the loader is then useless.
Enough for now. I'll check in soon.
Oilless
04-27-2000 02:25:56
 Re: just got a 2N-my first tractor - a few questions in reply to Reno, Hudson River Valley, 04-25-2000 21:18:16
You have a neat tractor.The loader is comming directly off the tractors hydrolic pump.The arms need to be chained,so the pump will put full power to loader.Most all loaders you see on any N will have a pump running from off the engine.MOST N series tractors rarely had outboard hydrolics.I have seen many modifications on this system.The clutch on everything I ever drove was on the left.
tlak
04-26-2000 13:20:58
If you hit the clutch and brake at about the same time you might have been switched in your thinking as to which one was accutely doing what.
Marc(MO)
04-26-2000 06:35:45
You have to shut the gas off or it might flood the crankcase with gas and dilute the oil if there is a problem with the carb. The lift arms have to be chained down because the loader uses the same pump as the lift and when the lift arms cant move then all the oil is directed to the loader's hydraulic system.
tlak
04-26-2000 06:09:22
As the Ns progressed the brake pedals moved to both on the right side but the clutch was on the left. For your other questions some of the N gurus will be along or repost on the N board. As weither your crazy or not you will have to ask Dr Zane.
