Select-O-Speed
HELP!
Lyle Stallman
04-08-2000 19:01:33
I recently purchased a Ford 901 Select-O-Speed.
Gears R2,3,4,7,8,10 work.
Gears R1,1,2,5,6,9 don't work.
According to the SOS diagnostic chart on the Vintage Tractors site, this condition means that the "overriding clutch does not apply". The only reason cited for this condition is the "overriding clutch is inoperative."
Can someone tell me what's involved in repairing this condition? Are "overriding clutch" parts - or unit - available? From Ford/New Holland? Others?
Thanks for any help you can provide.
matt
04-17-2000 08:08:35
 Re: Select-O-Speed - HELP! in reply to Lyle Stallman, 04-08-2000 19:01:33
The first thing you have to do is to do a pressure check on the system. This will give you an idea where the problem lies. It could also be incorrect fluid in the trans.. I have a 901 that didn't have the Ford fluid in it and 3,4,7,8,10 didn't work. I would do the pressure check first because the fluid from Ford is about $60 cto change good luck
chris mcgowan
07-18-2002 17:49:31
 Re: Re: Select-O-Speed - HELP! in reply to matt, 04-17-2000 08:08:35
I need the schematics on a ford 4000 select-o-speed transmission PLEASE HELP
jeff
08-18-2002 18:38:16
 Re: Re: Re: Select-O-Speed - HELP! in reply to chris mcgowan, 07-18-2002 17:49:31
check ebay. they have a listing.
