Hi Folks - got the father in laws Jubilee in the garage this morning, armed with a gasket/o-ring set for the lift cover. BTW, his main complaint was that on cold mornings, the hydraulics worked good, but if trying to get it to go on a warm day, it would take sometimes 5 minutes for the arms to come up. Anyway, we got the lift cover done, new o-rings on piston, & others. Put it back together, and NADA. While we had the oil drained, I cleaned about 2 full cups of gunky grease from the bottom. Pulled the lift cover back off, just to re-check, and all seemed ok.. the piston wasn't stuck, etc. Put an inverted cup over the pressure line, started it up, and the oil just 'flowed'. It didn't seem to have any pressure to speak of. I thought it should really shoot out. Also, there was an o-ring ridge on the casting, but the I&T manual doesn't show one, and there wasn't one there. Since the oil was flowing, does this mean the prime was ok? Rebuild of the hydraulic pump time? It is one of the Piston style. Thanks, Tim
