Order Ford 861 Parts Online
861 plow
Steve
02-18-2000 12:43:33
Any info on what size plow an 861 should pull would be appreciated.
Thanks-Steve J.
Gregg, Ohio
02-25-2000 20:40:14
 Re: 861 plow in reply to Steve, 02-18-2000 12:43:33
My uncle bout a 861 Ford new, and it came with 3 14" Ford plow. He later traded it in for a 3 16" to better match the furrows of another tractor and plow he had. 3 16`s was a load but worked...:)
Duke
02-20-2000 10:43:53
I pull 2 16's with my 861 in a heavy type soil. The tractor has no problem with this.
6000 COM
02-18-2000 18:06:12
3/16 no problem you may need to add about 2500 lbs of weight
will
02-18-2000 14:34:57
I recommend 2 16's. It has enough power for 3 16's but not enough traction.
Jim(UT)
02-18-2000 16:54:48
 Re: Re: 861 plow in reply to will, 02-18-2000 14:34:57
Some on this board have said it depends on what type of soil you encounter. Three 16s will work in some types of soil but not in clay.
