????? must weld crack 54 ford cast iron block ?????
brian
02-04-2000 19:28:09
how to properly weld crack in cast iron block 1954 ford crack in water jacket.
Jeremy Briansky
09-25-2003 15:58:22
 Re: ????? must weld crack 54 ford cast iron block in reply to brian, 02-04-2000 19:28:09
I have found a site that explains all about how to weld cast iron. Yes, that includes engine blocks. The site was www.muggyweld.com
Knapweed
02-06-2000 12:59:20
 Re: ????? must weld crack 54 ford cast iron block ????? in reply to brian, 02-04-2000 19:28:09
Page back to 1/31/00, to "Welding tips cast iron". I put in some info about arc welding under my Knapweed handle. Good luck.
ZANE
02-06-2000 08:24:32
If the block is cracked on the outside it should not be welded because it can't be successfuly welded. It will just make bad matters worse. Grind out all the dirt and paint from around the crack and smear on some JB weld or equivelent in 3M etc. let it cure overnight and put the coolant back in and go to work. There may be someone who can weld it but I have welded most of my life and tried it a few times without much success but unless it is a crack that will cause the front wheels to fall off or such don't try to weld it. If it is cracked inside the combustion chamber it is sometimes possible to pin the crack but welding just won't work on cast iron. If pinning won't work just say a few words over it and get on with hunting an engine.
darryl
02-04-2000 19:59:00
secret to welding cast iron is to preheat the metal in order to get equal and good penetration.
