Need help with tractor id
john
01-13-2000 13:44:25
i got a tractor and dont know what year or engine size it a older ford 4 cly diesel the best that i can find on it is the numbers above the starter are 631-d-s , but im not sure about the 6 battery acid has got the best of it. is there any other place to find out about it. thanks for any help john
Jim(UT)
01-13-2000 15:06:58
 Re: need help with tractor id in reply to john, 01-13-2000 13:44:25
I've seen that problem on x01 series before. 631 calls out a 601 series. The D means diesel. I've only seen one tractor with an S after the D and it had a Sherman aux tranny. I assume the S stands for Sherman. Does yours have a sherman? If so it will have a shifter handle on the left side of the trans case. the serial number should be under the 631 DS. May have succumbed to battery acid too. Check the site below for better info. Good Luck.
