Re: water drip from clutch area
RickB.
10-09-1999 16:30:07
Yes, there are 4 expansion plugs; 3 into the water jacket, one of these is in the back of the head with 2 in the rear of the block. The fourth is a large plug covering the rear of the camshaft. Yes, you will have to split your tractor & remove the flywheel & spacer plate to access the plugs. You will need a new cork seal around the crankshaft rear main seal (which you may as well replace, too). Sorry, can't help with your swing motor.
GEO
10-09-1999 17:58:36
 Re: Re: water drip from clutch area in reply to RickB., 10-09-1999 16:30:07
The swing motor is probably the same as the Massey Ferguson. Might check with a MF dealer and see if they can help you. Yours is the first I have heard of a Ford having a swing motor.
Nathan
10-09-1999 18:37:11
 Re: Re: Re: water drip from clutch area in reply to GEO, 10-09-1999 17:58:36
Thanks for the response fellows. It's what I thought but didn't want to accept. The hoe is not used very often. I might try some stop leak. The Ford dealer didn't know about swing motor either. He said if I would bring hoe model #, he might be able to help. I found that and will check it out. The hydraulic swing motor works real smooth because there is no slack like with chains or bushings and pins. Nathan
