Radiator Cap. Flat Tires
Gary
08-09-1999 07:23:14
Does anyone know what pressure radiator cap I should use on an 8n? Mine is old and does not hold any pressure. Is stays cool though. Also, does anyone have experience with putting foam in their front tires. I have a lot of mesquite to cut and keep getting flats. I would be interested in any other solutions anyone might have. It is a real pain to fix flats in Texas in August. Thanks, Gary.
larry
08-13-1999 08:34:47
 Re: Radiator Cap. Flat Tires in reply to Gary, 08-09-1999 07:23:14
GARY try taking a junk front tire of the same
designe and cut the junk tire in half,then wrapp it around your good tire until the ends
come close together and drill some holes thru
the ends of the junk tire and put some heavy
baling wire thru holes and stich then together
i know this sounds STUPID but it does work
good luck.
