Re: 2N leaking hydraulic fluid
Gary H.
08-12-1998 19:12:52
: I have a 2N that is leaking hydraulic fluid from the right rear where the lower right 3-point lift arm attaches. There is one nut to tighten that won't stay tightened. Is their a special gasket?
You will have to remove the trumpet housing to repair the leak. The pin has a nut on the inside.
