1. How do I identify which carb I have? I'm sure it's going to need rebuilding
2. Tractor has been converted to 12V neg ground with a Delco Alternator. The pulley is very rusty and I need to replace it. Any idea how to ID the alternator to make sure I get the right pulley?
3. The exhaust pipe is loose where it connects to the manifold. I've ordered a new clamp but is there a donut gasket supposed to be there?
4. Best place to find a spin on oil filter adapter? I'd rather not spill so much oil every change.
5. Any tips on R&R the rear wheels by yourself? obviously large and heavy, I'm thinking there must be a way to do it by yourself
6. PTO overrun clutch... I found one that also adapts the 1.125" shaft to 1.375" Wouldn't this kill two birds with one stone? And be cheaper than buying a new shaft?
7. The front wheel track is very wide at 6ft. I see there are numerous holes in the bars that make up the front end. I assume the track can be narrowed by changing the bolt positions?
I've used the search function but could not find the answers to these questions and I'm sure I'll have more.... :shock:
