Hello, I recently acquired an old tractor from my Dad. After reading this forum quite a bit, I believe it is a 49 Harry Ferguson TO-20. The serial number is right under the front of the steering wheel. It reads TO-13846 Harry Ferguson INC. Detroit Mich. USA. The starter switch is the gear shifter. After checking the fluids, installing a battery and giving the carberator a good cleaning, to my surprise it started right up. It actually sounds very good and drives good. It has a few issues though. First the PTO shaft vibrates and the seal leaks. After reading several post, I went ahead and pulled the bolts and after some pretty rough persuasion pulled the shaft out, and sure enough it has a twist on the spline on the inside. I would like to know what it would cost to buy a new one along with the seal. The other problem was that the 3 point lifts and will not go down until after some time to bleed down. After looking at several post on here I pulled the inspection plate and sure enough the Vert. Fork was not connected to the control valve T. I reconected it and It worked like it should for about 5 or 6 times. Then it fell off again. Is there a clip or something that is supposed to hold it on? Or is something worn that I need to replace? (Linkage, Contol Fork, or Valve?) I would like to know for sure what tractor this is before I started buying parts for it. Thanks, Karl
