Toora Stephen
I drove my tractor into a hole.
The right front wheel hit it pretty hard. I couldn't back it out.
The front wheel is in a hole.
The inner bolt has snapped. The other bolt is bent. Even if I could back it out, the wheel will not support the tractor.
The oil pan is sitting on the ground.
There was just enough room to get a jack under it, then jack it up to get blocks under the front, then move the jack forward and jack it up more to get the wheel out of the hole. Then the bolts had to be replaced in-situ. Not a bad job, really. The hardest bit was getting the VERY HEAVY jack across the field to the tractor.
- TS
- TS
