Bob (Aust)
[b:20e40b8dc7]Ferguson Tractor Tips, Hints & Suggestions[/b:20e40b8dc7]
Over the past three years I have participated in this forum, I have seen many very excellent tips, hints and suggestions on maintaining and operating our old Ferguson tractors.
Indeed, I learned more from this forum in three years, than I did in my previous 25 years of owning my TEA20 Little Grey Fergy!
New users join our forum and often ask the same questions which have been asked and answered a number of times previously.
I wonder if we can accumulate many of these excellent tips, hints and suggestions all in one thread, both to refresh old memories and for assistance and help to our newer Members?
My contribution, in no particular order:
[list:20e40b8dc7][b:20e40b8dc7]*[/b:20e40b8dc7] Ferguson tractor Serial Numbers are stamped into the data plate attached to the dash in front of the steering wheel. The year of manufacture of Ferguson serial numbers is listed in the Research Section in the left hand column of this site.
[b:20e40b8dc7]*[/b:20e40b8dc7] The FENA web site has the wiring diagrams for all models of the TE/TEA/TO tractors along with a wealth of other restoration data. [b:20e40b8dc7]FENA Web Site[/b:20e40b8dc7]
[b:20e40b8dc7]*[/b:20e40b8dc7] The date of manufacture is cast into the right side of the TE/TEA transmission housing, between the gear box flange and round inspection port hole.
[b:20e40b8dc7]*[/b:20e40b8dc7] Engine firing order is 1 – 3 - 4 – 2.
[b:20e40b8dc7]*[/b:20e40b8dc7] TEA20 timing marks are on the flywheel. It is necessary to remove the starter motor to find see the timing marks.
[b:20e40b8dc7]*[/b:20e40b8dc7] A Service Manual is the cheapest investment you will make.
[b:20e40b8dc7]*[/b:20e40b8dc7] Ferguson transmission takes normal engine mineral oil. Hydraulic or heavy gear oil must not be used.
[b:20e40b8dc7]*[/b:20e40b8dc7] With battery polarity, the “earth” side of the coil always goes to the distributor; "live" side to the ignition switch. (e.g. Battery Positive (+) to earth/ground = Positive (+) side of the coil to the distributor).[/list:u:20e40b8dc7]
I’m sure you guys will have many more excellent tips, hints and suggestions to add to the list?
Bob in Oz
’53 TEA20
Bob in Oz
’53 TEA20
